Can not save record(data) into database mySQL Using Delphi 10.3 Rio in Release Mode
ksi
Dear Brovin Yaroslav
First of all I would like to thank you for this great product (FGX component). I have a problem when using TFgActivityDialog in "Release Mode" in Delphi 10.3 Rio. When i deploy my Android Application in PlayStore, the application can not save record into mySQL Server, meanwhile in "Debug Mode" (Developement) it can save record into MySQL Server. What should i do to make mycode work in "Release mode" (playStore)? Please help me...
Here is the code i wrote:
procedure TLocationForm.btnSendClick(Sender: TObject);
    with dmMyLocation do
      if not fgActivityDialog.IsShown then
        FActivityDialogThread := TThread.CreateAnonymousThread(procedure
            TThread.Synchronize(nil, procedure
              fgActivityDialog.Message := 'Please, Wait';
              fgActivityDialog.Show;
            end);
            Sleep(1000);
            if TThread.CheckTerminated then
              Exit;
              fgActivityDialog.Message := 'Sending data...';
              qInsert.SQL.Clear;
              qInsert.SQL.Add('INSERT INTO mabsensilokasi(');
              qInsert.SQL.Add('idlokasi,');
              qInsert.SQL.Add('tgllokasi,');
              qInsert.SQL.Add('latx,');
              qInsert.SQL.Add('longx,');
              qInsert.SQL.Add('latlongx,');
              qInsert.SQL.Add('namalokasi) ');
              qInsert.SQL.Add('VALUES(');
              qInsert.SQL.Add(':idlokasi,');
              qInsert.SQL.Add(':tgllokasi,');
              qInsert.SQL.Add(':latx,');
              qInsert.SQL.Add(':longx,');
              qInsert.SQL.Add(':latlongx,');
              qInsert.SQL.Add(':namalokasi)');
              qInsert.Prepare;
              qInsert.Params[0].AsInteger := 0;
              qInsert.Params[1].AsDateTime := Now;
              qInsert.Params[2].AsFloat := strToFloat(ENUSLat);
              qInsert.Params[3].AsFloat := strToFloat(ENUSLong);
              qInsert.Params[4].AsString := ENUSLat+':'+ENUSLong;
              qInsert.Params[5].AsString := edtNamaLokasi.Text;
                UniConnection1.Connect;
                qInsert.ExecSQL;
                ShowMessage('Record was save into MySQL Server DB...'); //showup windows of dialog when data was save succesfully into db mysql server
              except
                on e:exception do
                  ShowMessage(e.Message);
                  UniConnection1.Disconnect;
                end;//exception
              end;//try
              //fgActivityDialog.ExecuteAction(btnSend);
            end);
            Sleep(1000);
              Exit;
              fgActivityDialog.Message := 'Finish';
            end);
            Sleep(500);
              Exit;
            if not TThread.CheckTerminated then
                fgActivityDialog.Hide;
              end);
          end;//try
        end);//FActivityDialogThread
        FActivityDialogThread.FreeOnTerminate := False;
        FActivityDialogThread.Start;
      end;//if
    end;//endDM
end;//endProc
          Sleep(1000);
            Exit;
          end);
              qInsert.SQL.Clear;
              qInsert.Prepare;
                qInsert.ExecSQL;
                  ShowMessage('Record was saved into MySQL Server DB...'); //showup windows of dialog when data was save succesfully into db mysql server
                end);
              except
                on e:exception do
                  end);
                end;//exception
              end;//try
            Sleep(1000);
              Exit;
            end);
            Sleep(500);
              Exit;
              end);
          end;//try
      end;//if
    end;//endDM
end;//endProc
I have changed your code a little bit. To make some kind of separation.
Изменено пользователем IVGSoft
Dear IVGSoft
I have tried the code you suggested but the result is the same as before. In Development Mode (Debug) the code works well but when i change the application to Release Mode (Application Store) the code did not work well (data can not save into database MySQL Server). Meanwhile the code in debug mode and release mode is the same.
Whould you please help me to solve it? Thank you very much for your help!
