BroadcastReceiver.OnReceive срабазывает 2 раза
x11
Так и должно быть, что событие "BroadcastReceiver.OnReceive" срабатывает 2 раза подряд?
Код создания. Проверял: создается только один BroadcastReceiver.
procedure TDMSrv.CreateBroadcastReceiver;
  BroadcastReceiver := TCSBroadcastReceiver.Create(nil);
  BroadcastReceiver.OnReceive := BroadcastReceiverOnReceive;
  BroadcastReceiver.RegisterReceive;
  BroadcastReceiver.Items.Clear;
  BroadcastReceiver.Add(PHONE_STATE);
  BroadcastReceiver.Add(NEW_OUTGOING_CALL);
  Log('CreateBroadcastReceiver');
Сам код события:
procedure TDMSrv.BroadcastReceiverOnReceive(csContext: JContext; csIntent: JIntent);
  log('BroadcastReceiverOnReceive');
  CheckPhoneCallState(csContext, csIntent);
Ну и сама процедура обработки:
procedure TDMSrv.CheckPhoneCallState(Context: JContext; Intent: JIntent);
  telephonyService: JObject;
  telephonyManager: JTelephonyManager;
  state: JString;
  incomingCallNumber: string;
  outgoingCallNumber: string;
  outputResult: string;
  Log('CheckPhoneCallState: ' + JStringToString(Intent.getAction));
  outputResult:= sLineBreak;
  telephonyService := TAndroidHelper.Context.getSystemService(TJContext.JavaClass.TELEPHONY_SERVICE);
  telephonyManager := TJTelephonyManager.Wrap((telephonyService as ILocalObject).GetObjectID);
  if JStringToString(Intent.getAction).Equals(PHONE_STATE) then
    state := Intent.getStringExtra(TJTelephonyManager.JavaClass.EXTRA_STATE);
      if state.equals(TJTelephonyManager.JavaClass.EXTRA_STATE_IDLE) then
        outputResult:= outputResult + 'Phone is IDLE ' + sLineBreak
        if state.equals(TJTelephonyManager.JavaClass.EXTRA_STATE_RINGING) then
          incomingCallNumber := JStringToString(Intent.getStringExtra(TJTelephonyManager.JavaClass.EXTRA_INCOMING_NUMBER));
          if incomingCallNumber.Equals('') then
            incomingCallNumber:= 'PRIVATE NUMBER';
          outputResult := outputResult + 'Phone is RINGING' + sLineBreak;
          outputResult := outputResult + 'Incoming call from ' + incomingCallNumber + sLineBreak;
          LaunchNotification(incomingCallNumber, 'Входящий вызов');
          InsertTel(incomingCallNumber, True);
        end
        if state.equals(TJTelephonyManager.JavaClass.EXTRA_STATE_OFFHOOK) then
          outputResult:= outputResult + 'Phone is OFFHOOK' + sLineBreak;
  end
    if JStringToString(Intent.getAction).Equals(NEW_OUTGOING_CALL) then
      outgoingCallNumber:= JStringToString(Intent.getStringExtra(TJIntent.JavaClass.EXTRA_PHONE_NUMBER));
      outputResult:= outputResult + 'Outgoing call to ' + outgoingCallNumber + sLineBreak;
      LaunchNotification(outgoingCallNumber, 'Исходящий вызов');
      InsertTel(outgoingCallNumber, False);
  Log(outputResult);
Изменено пользователем x11
Что-то мне кажется, если подпись идет на два типа событий: "отслеживание входящего звонка" и "смена состояния телефона", то логично, что событие срабатывает два раза.
Проблема в том, что и код добавления записи в базу "InsertTel(incomingCallNumber, True);" тоже срабатывает дважды.
Да и обратите внимание, что срабатывает одно и то же событие дважды - PHONE_STATE
9 часов назад, Brovin Yaroslav сказал:
Пробовали регистрировать ресивер не программно, а через манифест файл?
Пробовал когда-то. Но я не знаю, какую мою процедуру прописывать в манифест. Ведь мои процедуры работают внутри FMX и Android их не видит.
И еще убедитесь по логам, что вы не создали случайно два ресивера.
Проверял.
14 часа назад, x11 сказал:
ещё раз перепроверю
В 31.01.2018 в 23:41, Brovin Yaroslav сказал:
Событие "android.intent.action.PHONE_STATE" - это и есть отслеживание входящего звонка, т.е. смена состояния телефона.  Других событий для отслеживания входящего звонка вроде бы нету. Если есть, подскажите решение. Спасибо.
В 31.01.2018 в 23:55, Brovin Yaroslav сказал:
http://blog.mmarvick.com/blog/lollipop-multiple-broadcastreceiver-call-state/
это проблема андроида
