97mik Опубликовано 20 февраля, 2014 Поделиться Опубликовано 20 февраля, 2014 Возможно ли соединить 2 или более устройств по Bluetooth? То есть чтобы например на одном устройстве был сервер, а на остальных клиент. Bernardhums 1 Ссылка на комментарий
0 Администраторы Brovin Yaroslav Опубликовано 10 марта, 2014 Администраторы Поделиться Опубликовано 10 марта, 2014 По официальному свежему RAD Studio, Delphi and C++Builder Roadmap - March 2014 такая поддержка возможно появится в этом году: Features and Technologies Expected in 2014 The main themes for RAD Studio in 2014 are the additions of C++ for Android, quality, performance, and architectural improvements, an enhanced single-source multi-device designer and runtime, and enhancements of the remoting and multi-tier architecture for enterprise applications. We also anticipate delivering several new VCL components and features. Here are some of the technologies and features we are working on and expect to release over two major releases during 2014: Complete C++ toolchain for Android QPS (Quality, Performance, Stability) Advertising and Payments components for Android and iOS DataSnap middleware enhancements (performance, REST mapping, architectural improvements) Further enhanced single source multi-platform support with new multi-device visual designers and new, flexible user interface components Mobile Backend as a Service (MBaaS components, interfacing with some of the key providers, like Parse and Kinvey Mobile and desktop applications interoperability Android KitKat specific support Easy-to-use Windows taskbar buttons component for VCL applications Improvements in VCL styles and in the support for VCL applications on Windows Intel tablets, with specific styles and sensor components Direct support for wearable Android devices with particular form factors, particularly Google Glass Apache HTTP server modules support for WebBroker and DataSnap, alongside with the current ISAPI IIS support Several run time library (RTL) improvements, implemented for all platforms and involving areas like XML processing, JSON processing, among others. FireDAC new drivers and enhancements to existing drivers, including support for newer database versions Support for future versions of Android and iOS, expected to be announced by Google and Apple during the current year. Bluetooth support (for mobile devices) A new release of the C++ compiler for Win32, with full support for the C++ 11 language specification Ссылка на комментарий
0 Администраторы Brovin Yaroslav Опубликовано 15 апреля, 2014 Администраторы Поделиться Опубликовано 15 апреля, 2014 В RAD Studio XE6 появилась поддержка передачи данных по беспроводной сети Wi-FI. Поддержка сети Bluethooth запланирована на будущие версии. Компоненты взаимодействия приложений называются: "Application Tethering Components". Они позволяют легко осуществить взаимодействие ваших приложений друг с другом, написанных для разных платформ. Подробнее о новых компонентах тут: Using App Tethering Andrey Efimov 1 Ссылка на комментарий
0 Администраторы Brovin Yaroslav Опубликовано 7 сентября, 2014 Администраторы Поделиться Опубликовано 7 сентября, 2014 Полная поддержка Bluethooth была добавлена в RAD Studio XE7 Ссылка на комментарий
97mik
3 ответа на этот вопрос
