ошибка external exception 36 при создании токена FCM
Denisviz
Здравствуйте, хочу настроить Push уведомления на андроиде, делал по примеру с документации http://docwiki.embarcadero.com/RADStudio/Rio/en/Firebase_Android_Support
При запуске программы выдает ошибку  "external exception 36" или "external exception D6". Подскажите пожалуйста, может где-то  нужно расширить дозвала. Заранее спасибо
unit Unit1;
interface
  FMX.Types, FMX.Controls, FMX.Forms, FMX.Graphics, FMX.Dialogs, FMX.PushNotification.Android,
  FMX.Memo.Types, FMX.Controls.Presentation, FMX.ScrollBox, FMX.Memo, System.PushNotification, JSON,
  FMX.StdCtrls, FMX.Helpers.Android, FMX.Objects,FMX.Platform;
  TForm1 = class(TForm)
    MemoLog: TMemo;
    Button1: TButton;
    procedure OnReceiveNotificationEvent(Sender: TObject; const ServiceNotification: TPushServiceNotification);
    procedure OnServiceConnectionChange(Sender: TObject; PushChanges: TPushService.TChanges);
  private
  FDeviceId: string;
  FDeviceToken: string;
    { Private declarations }
    { Public declarations }
  Form1: TForm1;
{$R *.fmx}
   PushService: TPushService;
   ServiceConnection: TPushServiceConnection;
   Notifications: TArray<TPushServiceNotification>;
   PushService := TPushServiceManager.Instance.GetServiceByName(TPushService.TServiceNames.GCM);
   ServiceConnection := TPushServiceConnection.Create(PushService);
   ServiceConnection.Active := True;
   ServiceConnection.OnChange := OnServiceConnectionChange;
   ServiceConnection.OnReceiveNotification := OnReceiveNotificationEvent;
   FDeviceId := PushService.DeviceIDValue[TPushService.TDeviceIDNames.DeviceId];
   MemoLog.Lines.Add('DeviceID: ' + FDeviceId);
   MemoLog.Lines.Add('Ready to receive!');
   // Checks notification on startup, if application was launched fromcold start
   // by tapping on Notification in Notification Center
   Notifications := PushService.StartupNotifications;
   if Length(Notifications) > 0 then
       MemoLog.Lines.Add('-----------------------------------------');
       MemoLog.Lines.Add('DataKey = ' + Notifications[0].DataKey);
       MemoLog.Lines.Add('Json = ' + Notifications[0].Json.ToString);
       MemoLog.Lines.Add('DataObject = ' + Notifications[0].DataObject.ToString);
procedure TForm1.OnServiceConnectionChange(Sender: TObject;  PushChanges: TPushService.TChanges);
   PushService :=
   if TPushService.TChange.DeviceToken in PushChanges then
       FDeviceToken :=
 PushService.DeviceTokenValue[TPushService.TDeviceTokenNames.DeviceToken];
       MemoLog.Lines.Add('FireBase Token: ' + FDeviceToken);
       Log.d('Firebase device token: token=' + FDeviceToken);
   if (TPushService.TChange.Status in PushChanges) and (PushService.Status
 = TPushService.TStatus.StartupError) then
       MemoLog.Lines.Add('Error: ' + PushService.StartupError);
procedure TForm1.OnReceiveNotificationEvent(Sender: TObject;const ServiceNotification:TPushServiceNotification);
  MemoLog.Lines.Add('DataKey = ' + ServiceNotification.DataKey);
  MemoLog.Lines.Add('Json = ' + ServiceNotification.Json.ToString);
  ServiceNotification.DataObject.ToString);
  MemoLog.Lines.Add('---------------------------------------');
end.
Изменено пользователем Denisviz
ошибка
Ответов пока нет
