constructor TLocationListener.Create(AParent: TForm1);
inherited Create;
FParent := AParent;
procedure TLocationListener.onLocationChanged(location: JLocation);
FParent.onLocationChanged(location);
procedure TLocationListener.onProviderDisabled(provider: JString);
procedure TLocationListener.onProviderEnabled(provider: JString);
procedure TLocationListener.onStatusChanged(provider: JString; status: Integer;
extras: JBundle);
{ TForm1 }
LocationManagerService: JObject;
iter : JIterator;
if not Assigned(FLocationManager) then
LocationManagerService := TAndroidHelper.Context.getSystemService(TJContext.JavaClass.LOCATION_SERVICE);
FLocationManager := TJLocationManager.Wrap((LocationManagerService as ILocalObject).GetObjectID);
if not Assigned(locationListener) then
locationListener := TLocationListener.Create(self);
FLocationManager.requestLocationUpdates(TJLocationManager.JavaClass.GPS_PROVIDER, 10000, 10, locationListener,
TJLooper.JavaClass.getMainLooper);
iter := FLocationManager.GetAllProviders.Iterator;
ListBox1.Clear;
while iter.hasNext do
ListBox1.Items.Add(JStringToString(iter.next.ToString));
CheckBox1.IsChecked := FLocationManager.isProviderEnabled(TJLocationManager.JavaClass.GPS_PROVIDER);
CheckBox2.IsChecked := FLocationManager.isProviderEnabled(TJLocationManager.JavaClass.NETWORK_PROVIDER);
location := FLocationManager.getLastKnownLocation(TJLocationManager.JavaClass.GPS_PROVIDER);
except
on e:Exception do showmessage('Ошибка :'+e.Message);
destructor TForm1.Destroy;
if Assigned(locationListener) then
FLocationManager.removeUpdates(locationListener);
inherited;
bossalex
пробовал на Delphi 10.1.2 вот это код пашет, но был вариант и под RIO пахал, но сейчас нет посеял AndroidManifest.template.xml файл проекта прикрепил
unit Unit1;
interface
Androidapi.JNI.Location, Androidapi.JNIBridge, Androidapi.JNI.JavaTypes,
Androidapi.JNI.Os,Androidapi.Helpers, FMX.Layouts, FMX.ListBox, FMX.StdCtrls,
FMX.Controls.Presentation;
TLocationListener = class;
TForm1 = class(TForm)
Button1: TButton;
ListBox1: TListBox;
CheckBox1: TCheckBox;
CheckBox2: TCheckBox;
Label1: TLabel;
Label2: TLabel;
Label3: TLabel;
Label4: TLabel;
Label5: TLabel;
Label6: TLabel;
{ Private declarations }
private
FLocationManager : JLocationManager;
locationListener : TLocationListener;
destructor Destroy; override;
{ Public declarations }
procedure onLocationChanged(location: JLocation);
TLocationListener = class(TJavaLocal, JLocationListener)
private
[weak]
FParent : TForm1;
constructor Create(AParent : TForm1);
procedure onLocationChanged(location: JLocation); cdecl;
procedure onProviderDisabled(provider: JString); cdecl;
procedure onProviderEnabled(provider: JString); cdecl;
procedure onStatusChanged(provider: JString; status: Integer; extras: JBundle); cdecl;
Form1: TForm1;
{$R *.fmx}
uses FMX.Helpers.Android, Androidapi.JNI.GraphicsContentViewText;
{ TLocationListener }
inherited Create;
FParent := AParent;
extras: JBundle);
{ TForm1 }
iter : JIterator;
ListBox1.Clear;
except
inherited;
procedure TForm1.onLocationChanged(location: JLocation);
Label4.Text := location.getLatitude.ToString;
Label5.Text := location.getLongitude.ToString;
Label6.Text := location.getAltitude.ToString;
end.
AndroidGPS.zip
Изменено пользователем bossalexдобавил файл проекта
0 ответов на этот вопрос
