Ошибка LocationSensor в iOS, постоянно выдает NAN.
Yuriy2606
Delphi Rio
При использовании LocationSensor в Android всё работает отлично. В iOS постоянно выдает NAN, не зависимо от аппарата и SDK.
Изменено пользователем Yuriy2606
Решение взято отсюда https://community.idera.com/developer-tools/general-development/f/tools-22/36905/help-delphi-locationsensor-not-giving-coordinates-anymore
You have to manually comment the file "System.iOS.Sensors.pas" and then add this file to your project.  This workaround is only for iOS deployment.  If you are also running programs in Windows it will give you an error, you will have to remove the file from the project.
"...\Embarcadero\Studio\20.0\source\rtl\common\System.iOS.Sensors.pas"
 and comment the line 151 as shown below:
function locationManagerShouldDisplayHeadingCalibration(manager: CLLocationManager): Boolean; cdecl;
//[MethodName('locationManager:didUpdateLocations:')]
This should work.
Думаю такие вещи должны быть тут.
