TImage в Base64
ZverA4
Подскажите плиз, как закодировать TImage в Base64 для передачи серверу?
Я делаю так:
    TStream *UserJPGS = new TStream;
    BmpTmpUser->Canvas->Bitmap->SaveToStream(UserJPGS);
    String sResult = "";
   sResult =  BytesToBase64(UserJPGS); //Ошибка тут
     DataUserReg->Add("photoreg="+sResult); //В POST улетело
    delete UserJPGS;
Содержимое BytesToBase64
String __fastcall BytesToBase64(TStream ArrayIn)
    TBase64Encoding *Encoding = new TBase64Encoding( 64, '\n' );
    String Result;
    Encoding-> Encode(ArrayIn, Result);
    delete Encoding;
    return Result;
Ругается:
[bccaarm Error] odarom.cpp(626): no viable conversion from 'System::Classes::TStream __borland_class *__strong' to 'System::Classes::TStream'
  System.Classes.hpp(1269): candidate constructor (the implicit copy constructor) not viable: no known conversion from 'System::Classes::TStream __borland_class *__strong' to 'const System::Classes::TStream &' for 1st argument; dereference the argument with *
  odarom.h(154): passing argument to parameter 'ArrayIn' here
Изменено пользователем Andrey Efimov
Добавил теги для кода и ошибок
{$IFDEF ANDROID}
function Encode_Stream( AStream: TStream ): string;
  LStream: TMemoryStream;
  AStream.Position:= 0;
  LStream := TMemoryStream.Create;
  TNetEncoding.Base64.Encode( AStream, LStream );
  LStream.Position := 0;
  Result := ReadStringFromStream(LStream, -1, IndyTextEncoding_8Bit);
function Decode_Stream( enc_str: string ): TMemoryStream;
  LStream: TStringStream;
  Result:= TMemoryStream.Create;
  LStream:= TStringStream.Create;
  LStream.WriteString( enc_str );
  LStream.Position:= 0;
  TNetEncoding.Base64.Decode( LStream, Result );
{$ELSE}
function Encode_Stream(AStream: TStream): string;
  Result:= TIdEncoderMIME.EncodeStream(AStream);
function Decode_Stream(enc_str: string): TMemoryStream;
  TIdDecoderMIME.DecodeStream(enc_str, Result);
{$ENDIF}
function LoadBitmapFromStream(const AStream: TStream; const Bitmap: TBitmap): Boolean;
  Bmp: TBitmapSurface;
  Result := False;
  Bmp := TBitmapSurface.Create;
    Bmp.Assign(Bitmap);
    Result := TBitmapCodecManager.LoadFromStream(AStream, Bmp);
    Bitmap.Assign(Bmp);
    FreeAndNil(Bmp);
function SaveBitmapToStream(const AStream: TStream; const Bitmap: TBitmap; const Extension: string;
  SaveParams: PBitmapCodecSaveParams = nil): Boolean;
  surf: TBitmapSurface;
  Result := False;
  surf := TBitmapSurface.Create;
  surf.Assign(Bitmap);
    Result := TBitmapCodecManager.SaveToStream(AStream, surf, Extension, SaveParams);
    surf.Free;
function Bitmap_To_Base64(bmp: TBitmap; const AQuality: Integer = 85): string;
  eStream: TMemoryStream;
  SaveParams: TBitmapCodecSaveParams;
  eStream:= TMemoryStream.Create;
  SaveParams.Quality := AQuality;
  SaveBitmapToStream(eStream, bmp, '.jpg', @SaveParams);
  Result:= Encode_Stream(eStream);
  eStream.Free;
function Bitmap_From_Base64(b64_string: string): TBitmap;
  Result := TBitmap.Create;
  eStream := Decode_Stream(b64_string);
  if Assigned(eStream) then
    eStream.Position := 0;
    LoadBitmapFromStream(eStream, Result);
    eStream.free;
Скинул как есть. На цэ желания переводить нет, так-что смотрите сами... Надеюсь разберетесь
